I'm new to the Cyclops/Kubota series.. I need to replace the alternator/fan belt on my new to me 1782. It looks to be original... kinda dry and old looking... I don't trust it.
My question... Can the driveshaft be removed without moving the engine or transaxle? I'm thinking remove the four allen head bolts in the rear CV and maybe the whole shaft will come out thru the tunnel cover area?? Will the spline pull out of the engine CV without upsetting anything? ![]() Thanks in advance for the help
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
Yes, the driveshaft will come out that way, but I would take the front CV joint off too. I say this because in my opinion they both should be cleaned up, repacked with grease, have the rubber boots replaced if needed and have the o-ring in the CV joint replaced. I put a small zip tie around the rubber boot where it slips over the drive shaft and pull it fairly snug so the grease can't squeeze out.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
I have a 2182 I bought new and a 1782 and have only replaced the boots once on the 2182. As long as someone kept a little grease in them you shouldn't have to replace the balls.
I've only had to replace the ball bearings on one CV joint I've run across. It didn't look like the PO ever greased the CV joint,, and the joint looked like it had filled with water at some point. The pitting and erosion on the steel balls were extensive. I wish I had taken some pix of them for viewing.
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
The CV joints on my 1863 and 1864 have both been apart for cleaning/greasing a couple of times. I reused the o-rings as they weren't torn or crushed. I replaced the boots once and used the tie wrap at the shaft. With a good cleaning of the CV components, light scuffing could be found. I don't think the previous owner greased the joints. I just reused all the parts. Years later when I had the engine removed again, I redid the CV cleaning/grease. No change in light scuffing. Just repack with grease and reassemble. Once properly maintained, the CV joints should last a long time.
Thanks for all the info guys!
I have a bad feeling that mine hasn't seen grease in a long time.. It's still running true and not vibrating but if you grab it by hand and try to turn it there is some rotational slack.. I'm gonna pull it out this weekend and see what she looks like inside the joints.. I really don't want it to come apart on me while its running.. that would probably be bad!
Finally got some time to work on the 1782 for a minute. Disassembled the driveshaft, cleaned and repacked the CV joints.. I got an extra shaft from Sam a few weeks ago. Took both apart and used the best parts from both.
I used my old shaft, some new boots from Cub Cadet, two NOS splined couplers from epay, the outer couplers from Sam's shaft, and eight new ball bearings from McMaster Carr.. All put together made one like new driveshaft.. Chucked it up in my old South Bend and checked the run out.. only .005".. probably as good as it was when new.. Also picked up a new alternator belt.. A 7320 Gates belt fits like a glove.. Local Oriellys had it in stock. Now I just gotta get it all back in the tractor!
Lookin good Buddy. Should be SMOOTH................
Sam,
I'm sure it will be smooth for a smoker... BUT that Kubota gasser has already spoiled me!! It's like glass!!
