Old 04-19-2010, 12:19 AM
labrati labrati is offline
Default Driving a hydro with the S/G
So as I've been trouble shooting I noticed that if while the S/G is turning over I hit the Forward on the ground speed that the tractor will move. I suppose this makes sense as the shaft is spinning from the S/G. Does this harm anything? Is it normal for a hydro to be able to do this?
Old 04-19-2010, 02:33 PM
One of the reasons they come from the factory with a neutral safety switch is so that you can't do that.
Not really sure why anyone would want to do that anyway?!
Old 04-19-2010, 02:55 PM
So I should assume that my Neutral Safety switch is bad or bypassed... it might come in handy if the thing ever shut down on you... I know I once drove my landcruiser using the starter out of an intersection... do you think it would damage the hydro unit?
Old 04-19-2010, 07:45 PM
ALSO...when you depress the brake pedal to satisfy the Neutral Safety Switch, it is suppose to automatically place the hydro in the neutral position. Sounds like some devices are out of adjustment.
Old 04-19-2010, 10:03 PM
I does... however the brakes were horribly out of adjustment... I fixed those tonight... if the engine was running and you were on an incline with the hydro in neutral the tractor would start rolling down hill... YIKES!
