Old 06-08-2015, 09:37 PM
Wildbuckwheat Wildbuckwheat is offline
Default 108 muffler rusted out
Hi all, new member here who just bought his first cub this weekend. Its a 108.
The muffler is rusted out. Theres big holes in the side. Where can I get a replacement? And what other models use the exact same muffler (so I can expand my search for used mufflers).
How much blowby is normal? I read something about a negative vacuum crank pressure setup and I'm not familiar with that. Basically I have normal/not noticeable blow coming out of the crank breather. If I remove the dipstick there's more air coming out of the oil fill hole than the exhaust. Although typing this out I just remembered there's a big hole in my muffler so that maybe explains why not so much comes out of the pipe. I did disassemble the breather to make sure its clean and working. Its a k241 block (according to the sticker).
I'm sure the old k241 10hp is tired and its probably due for a rebuild, but it doesn't seem to burn any oil and fires right up, haven't even set the valves yet. Yup dummy me didn't realize the valves were behind the breather or I would have done it right away.
Old 06-08-2015, 09:55 PM
here ya go.
http://www.ebay.com/itm/KOHLER-ENGIN...item2c9bfc0101
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-08-2015, 11:21 PM
When you put the breather back in did you put the little hole toward the bottom so the oil will drain back into the engine rather than fill the breather up?
Old 06-09-2015, 08:00 AM
I thought that piece was pressed in, so I just cleaned the hole. Which is why I didn't see the valves. It's facing down.
Thanks folks.
