Old 06-07-2015, 04:12 PM
bocephus1991's Avatar
Default Anyone seen a blade like this?
Has anyone ever seen a blade/bucket like this? Wouldn't be hard to build. Thought it kinda neat.
Brian
Old 06-07-2015, 06:52 PM
I've seen those before but I don't know who made them. Neat setup, sort of like a Johnny Bucket.
Old 06-07-2015, 07:03 PM
twoton twoton is offline
I like it. Looks like it would work well for spreading gravel on the lane.
Old 06-07-2015, 07:38 PM
IHinIN IHinIN is offline
I've seen that picture before and thought of building one of them since I added the hydraulics to my 100 and could use my angle cylinder to dump the bucket.
Old 06-08-2015, 01:55 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
You could even add a lever to one side and use a rope to pull back on allowing you to dump whatever material you have loaded.
But if using a CC blade with forks is rather iffy, so to would using this bucket wanna be if you were to overload it.
http://www.onlycubcadets.net/forum/s...ad.php?t=39345
Old 06-08-2015, 05:05 PM
782CC 782CC is offline
JD uses a dedicated cylinder up there for lift which is why it can support a bucket load. Now if you built a solid mount setup and ran a cylinder for lift off the front aux port then you might have something to work with. But might as well do a johnny bucket as that point.
FYI - I tried to carry a 100lb IH front weight on my blade once. Messed up pins and bent the rockshaft arm as the blade slammed to the ground with a bump. And I thought I was going easy...
