Old 06-07-2015, 11:36 AM
yeeter yeeter is offline
Default Steering pin wear spots
Are these wear spots on this steering box a concern? (I will dig out the assembly and see how it works, but figure there are lots of good opinions here)
Old 06-07-2015, 11:49 AM
Berwil's Avatar
Berwil Berwil is offline
You should clean up the end of the pin so you can properly adjust it when you reassemble. I chucked mine gently in my cordless drill and brushed it a few times with a flap disc on a grinder. A drill press is probably easier so you don't have to hold/run 2 tools at once, but I don't have one. It worked great and pin came out like new.
Bill
Old 06-07-2015, 02:37 PM
RichardNoggin RichardNoggin is offline
You can find new ones on fleabay with all new ball bearings for $15 shipped. Search Cam Follower for Ross steering. While you are in there you might as well do the easy steer upgrade using a thrust bearing.
127, 129, 149, 42" blade, 2A Tiller
Old 06-07-2015, 07:38 PM
I sell new adjustment screws
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
$8 plus shipping
