Thread Tools
Display Modes
I picked up a 122 today with hydraulic lift,sleeve hitch and hydrostat transmission.one of my questions is did someone switch hoods or was hydro transmission an option?The previous owner said that the seal was bad on the hydraulic pump upon closer inspection I can see that the shaft has some side to side movement are parts available for these pumps?
Welcome to OCC
![]() Sounds like you have a 123 with a 122 hood. Your grill look like this one? ![]() |
![]() ![]() ![]() Edit- You beat me Jeff!
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 ![]() ![]() ![]() ![]() JD 2155 w/ 175 loader |
The lift pump. Ya Its the same. I will try and post pics of my 1650 project later.
Yes, parts are available, but for the main parts of the pump they are pricey. Cub Cadet wants nearly $400 for the shaft..... but it's available. If you know of a hydraulic supplier, they may be able to get it cheaper. It's just a Sundstrand hydro unit. It's not CC specific. Your best bet is to just buy another unit. You can get a used one for around $75-$150 depending on where you look.
EDIT: Here you go: http://www.ebay.com/itm/CUB-CADET-10...item35eb27161e |
