Old 04-17-2010, 08:30 AM
cub1200puller's Avatar
cub1200puller cub1200puller is offline
Default smoken cub
I just got a cub 129 that smokes after it runs for a short while. It smokes so bad it fowls the spark plug in no time. It still has plenty of compression to run but i noticed what looks like oil coming from underneath the head gasket. Thier isnt much blow by coming from the dipstick tube while it runs. I hope its not a hole in the piston. Any guesses on what might have happened to it?
Old 04-17-2010, 08:58 AM
Amigatec's Avatar
Amigatec Amigatec is offline
I had a 8hp B&S do the same thing replaced the rings and it fixed the problem.
Pat Benner Haskell OK
Old 04-17-2010, 09:13 AM
Merk Merk is offline
It can be one of 2 things.
The crankcase breather is plug or installed the wrong way. There is a drain inside the breather housing that needs to be pointing down.
The other possible problem is the rings are shot. If that is the case you will need a new piston and rings. The best you can do do is rebuild the motor if the rings are shot.
A Kohler Service Manual will show you which way the breather goes and has a good section on how to rebuild a motor. Pay close attention on hoe to measure the cylinder bore.
The motor will not run if there was a hole in the piston.
Old 04-17-2010, 11:13 AM
If you've got oil coming out from under the head, you've got a blown head gasket. Fix that first and see if you still have a problem.
