Old 05-29-2015, 03:06 PM
mv7fd mv7fd is offline
Default Cub 100 deck aize
I am getting a cub cadet 100 and want to get a deck for it what deck fits on these tractors and will a mule driver from a narrow frame work fine or is it a 100 specific thing and are the decks regular mount like the 127's and stuff
Old 05-29-2015, 03:15 PM
cubby102's Avatar
cubby102 cubby102 is offline
The correct setup for a 100 is a bolt on/pin on setup. But I have seen quick attatch s3t ups from later narrow frames bolted to the machine. Originaly it would of had a cast end 38 or 42 inch deck. But later 38 and 42s will work as well
Old 05-29-2015, 03:24 PM
So will the new quick attach stuff bolt right up? I have a 127 with a deck I was thinking of taking that off for it
Old 05-29-2015, 03:41 PM
The 127 qa bracket should have the holes in it needed to bolt it to the 100.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-29-2015, 08:47 PM
cubby102's Avatar
Should yes
Old 05-29-2015, 11:52 PM
Will the mule drive off a 127 work as well
Old 05-30-2015, 12:53 AM
cubby102's Avatar
Yup should have the holes already in place
