Just spent some time in the cabinets of my shed looking for steering parts. Didn't find what I needed but did find something others might consider acquiring. In this day and age we believe the only way to measure RPM of our engines is with something electronic. If you buy one of these, you can be assured of accurate measurement of your engines RPM. Made in Germany and proven accurate and reliable by test.
It's called a SIROMETER. Before you click the link most will say what the heck is that. I'm pretty sure I made this purchase 10 years ago or better and forgot. SIROMETER LINK: http://www.treysit.com/16.html |
Now that is neat looking! Ever hook it up and use it?
-Ryan
I also have one of those sitting in a box, it takes a little bit of practice getting used to it and getting the wire in resonance and learning to spot that moment. I find my $12 photo tach much more convenient to use though, but if I ever ran out of batteries or something I would have no problem using the sirometer.
It doesn't "hook up" to anything! You just place it against the engine while it's running and turn the dial. As the dial turns the wire sticks out more and more at some point it will be in resonance with the frequency of the engine and will start to vibrate with a lot of amplitude. At that point you read the number on the dial and that's the RPM. Very neat device. |
you can buy them from Briggs & Stratton , they call them vibra tac , pretty much all I use on singles. mine looks just like the photo
if you use it enough you can tell if the engine has balance gears or not.
Are they usable on engines with more than one cylinder? I thought not , but the website has some large machinery listed on the examples page.
I remember using one of those in ag mechanics in high school! That's been a day or two ago! I outta get one.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
I think they work on 1 or 2 cylinder engines. I use mine alot, got it a couple years ago.
It's all I have to measure RPM. pretty cool once you get the hang of it.
- Tim 1872 60" Haban deck- 2082 450 blower, 50c deck - 1450,1650 2x44a deck, QA-42A snowthrower, 70 w/k181(destroyed) 38" pin on deck |
I've never used it on anything over a twin.
All our high school ag mech class was 1,2 cyl engines 2 and 4 cycle. Automotive did the larger engines.
