Old 05-28-2015, 03:39 PM
Lanceskene's Avatar
Lanceskene Lanceskene is offline
Default 109 owners??
Just curious what people think of them, pro and cons
Im to pick one up on sat that has the engine disassembled, the seller had intended to have it rebuilt but never did. I like the k241s and likely have any parts that might be needed. It looks reasonable and has a deck, no seat tho, but cheap. I buy/sell alot of GTs and wont know which way I'll go with it until I get it home and look it over, ideally it can be repaired, cleaned up and passed on to somebody else to use or fully restore.
Lance / Alberta Can
IH 127 w/deck, snowblade
IH 154 Loboy(x2) w/creeper 3pt and 3160 deck
CCC 12.5 w/deck
Plus 35 or so non IH tractors
Old 05-28-2015, 03:47 PM
When it comes to hydro tractors I don't really like anything smaller than a 12hp, as I understand it the hydro rear end is only about 80% efficient so a 10hp engine get cut down to 8hp. Plus I mow with a 48" deck and 10hp is borderline not enough power in my opinion.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-28-2015, 04:03 PM
Terry C's Avatar
Terry C Terry C is offline
You still get 10hp at the deck if you are sitting still right? So unless you mow everything up hill that loss wouldn't bother would it?
i don't know I mow with the 149 and a 38in deck so don't listen to me
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-28-2015, 04:55 PM
sawdustdad's Avatar
42 inch deck maxes out a 10hp. 48 inch really needs a 12hp+, Unless, or course, you cut the grass daily...
Old 05-28-2015, 09:01 PM
My 109 had a pretty tired 10 hp and a 42" deck on it when I got it, it did ok but I always it was a little under powered.
It now has a pretty fresh 10 hp and a 38" deck... I wouldn't have a problem with a 42" deck, but I would be concerned if I got behind and it was all I had to mow with.
Although, I also have a 105 with a 42" deck and it just kicks butt! So much so, that I let my Brother have it on permanent loan. AND THAT GUY can bend a crow bar in a sand pile!
Old 05-28-2015, 09:31 PM
JLM78 JLM78 is offline
Here's what I used, 109 with 44 as long keep you yard up
Old 05-29-2015, 01:05 AM
Lanceskene's Avatar
Thx, how easily are the decks removed for cleaning and maintenance? I think the last CC deck I had to deal with was an early '90s 1862 so that wont compare. Some of these older GTs require a contortionist and two trained monkeys to get a deck off.
I have two Cub projects here already so I doubt this 109 will be here long, but I like to sell 'good' stuff so I'll refresh the 241 and clean up the tractor, new seat... and hopefully get it into the $500-$600 range for resale.
Lance / Alberta Can
CCC 12.5 w/deck
Old 05-29-2015, 08:12 AM
It takes me about 2 minutes to take my deck off and about 3 to put it back on.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-29-2015, 10:50 AM
I'm not as adept at R & R ing these decks as Tim is, but yeah, a couple minutes off and a few back on. The hardest part is probably sliding them out and then back under, only because they are so heavy.
Old 05-29-2015, 06:39 PM
cub cadet 72 guy's Avatar
cub cadet 72 guy cub cadet 72 guy is offline
I timed myself putting it in without the belt for the fun or it and to answer this and it took me 1 minute and 17 seconds on my 129 at a normal pace.
1961 Original
1962 original w/ fenders and creeper
102
72 w/ fenders and lights
124 w/ sleeve hitch
129 w/ lights
5 mower decks, 2 plow blades, 1snowblower
