Old 05-17-2015, 09:24 AM
mattkarr mattkarr is offline
Default Setting the governor K301
I have tried to set the governor several times on my 127 it never seemed to act right and after looking at how the governor gear is designed I realized that it's possible when the weights are vertically aligned it may not set easily after turning the engine over by hand while setting the governor shaft made all the difference it now holds rpm perfectly. Just wanted to share thanks
Old 05-17-2015, 09:28 AM
Good info thanks for sharing
Old 05-17-2015, 01:52 PM
I've never had any kind of issues at all setting a governor. No matter what position the weights are in..... Perhaps your gear needs replaced?
Old 05-17-2015, 02:00 PM
Not sure but it makes sense just wanted to share a helpful tip for others that may have the same issue . Just something to try before the pull the motor lol
