Old 05-16-2015, 05:50 PM
Dadenstein Dadenstein is offline
Default 149 PTO clutch slipping
Hello all,
My current 149 is ready to cut grass, but the (freshly rebuilt) clutch is slipping so horribly that it won't even limp through grass. Any ideas?
Old 05-16-2015, 06:01 PM
I can only think of 2 possibilities, one you did something wrong when you rebuilt the clutch or your mower deck has a problem.
Old 05-16-2015, 06:09 PM
Sam, I doubt the deck has any problem. The governor does not trigger much if at all when the blades stall. What would I have done wrong in the clutch?
Old 05-19-2015, 08:30 AM
Default Update
As it turns out, the levers that hold the button in and that entire assembly was simply ultra loose and the slippage was remidied by taking the clutch off and tightening everything up.
Old 05-19-2015, 10:56 AM
You did use the required clutch tool to set the PTO fingers to the correct height?
The tools are in the upper right of this pic. There is a narrow frame gauge and a wide from gauge but either one works just fine on a wide from PTO.
