Old 05-11-2015, 04:59 AM
elshiv's Avatar
elshiv elshiv is offline
Default What kind of front tire should I go with?
I'd like to make the same request... Kinda. My 982 has a blown front tire and I wanted some opinions on what would work best. Debating between a regular turf tires or maybe 5 ring AG tires. Not sure what the benefits or con's are on either one.
Old 05-11-2015, 11:39 AM
sawdustdad's Avatar
Depends on what you are doing. If cutting grass mostly, I'd get a set of turf tires. If doing ground engaging work, I like ag tires. Not that they are particularly functional, but I like the look.
If you put ags on the front, be prepared for some good-natured ribbing from the folks here who believe (perhaps rightly so) that front ags only belong on 4WD/AWD/MFD tractors.
But it's your tractor. Don't listen to anybody else, do what you want!
Old 05-11-2015, 12:03 PM
jimbob200521's Avatar
I personally recommend the V61's from Miller Tire. Easy on ground yet the ribs provide good traction for turning in the winter snow. Plus they just look cool!
http://www.millertire.com/products/l...d-5-rib-4-ply/
-Ryan
Old 05-11-2015, 12:48 PM
sbauerz28's Avatar
V61's for all the same reasons Ryan stated above.
I can add one more reason the V61's are better than the turf tires. It's easier to clean dog poop off the tread.
Old 05-11-2015, 12:50 PM
elshiv's Avatar
I can add one more reason the V61's are better and the turf tires. It's easier to clean dog poop off the tread.
SOLD!
Javier~
1980ish 982 w/ 3pt. & PTO /50C deck - a Work in progress. Brinly Moldboard Plow.
I'm a complete noob at this so please take it easy on me.
Old 05-11-2015, 10:13 PM
I like the narrow tri-ribs or narrow ags on the fronts. They turn a lot easier than the V61's and they give it more of a tractor look. Both have about 1" surface contact with the ground and steering can be done easily with 1 finger with no front attachment on.
Old 05-11-2015, 11:30 PM
OldSkull's Avatar
OldSkull OldSkull is offline
V61 give better traction in snow and are easier to clean then turf but are they really better than 3 ribs or turf tire with a set of front chain for snow? All I can say for sure is they are better then the pair of small rib balloon's they replace on my 1650.
Gilles.
1963 100 (red)/in storage
Old 05-12-2015, 01:52 PM
elshiv's Avatar
Hey Guys,
Thanks for all the feedback. I ended up going with the V61 6 ply as I plan to buy or build a loader for the 982 eventually. So I figured the V61's would be better suited for that.
Javier~
Old 05-12-2015, 02:09 PM
Steve149's Avatar
Steve149 Steve149 is offline
I second that one!!!
Old 05-12-2015, 04:26 PM
I'd go with round. They work best.
