Old 05-08-2015, 07:15 AM
TigerCub's Avatar
TigerCub TigerCub is offline
Default 38" deck rebuild
Is there a trick to tearing down these spindles? I took the cup off the bottom but can't figure out how to get the pulley off.
Mine:
122 with 38" Deck, 123 with 48" Deck, 1650 with 44" Deck, #1 Tiller, QA42 Snowthrower
My Dad's:
Red 382 Hydro, Red 482 Gear
Old 05-08-2015, 07:49 AM
Darrell Darrell is offline
I have taken the pulleys off while they are still on the deck , but i guess you could put in it a vise to support it.
Spray some PB Blaster on the shaft , let it set for a few minutes. Put it in a fixture of some kind to support it , or bolt it back on the deck. Bolting back to the deck would probably be the easiest thing to do because you are going to be hitting the shaft with a BFH.
Get a pry bar wedged all the way under the pulley , have a friend help push down on the pry bar. A pry bar with a curved tip works the best.
Take a deep socket the same size of the shaft or a little smaller , place it on the shaft , with the friend holding down on the pry bar all the way under the pulley , take about a 3 lb hammer and start hitting the socket to force the pulley off.
If you have a big brass punch , that will work in place of the socket.
If you have a hydraulic press , no biggee to get it off. It is still pretty easy to do it the other way if the shaft isn't rusted really bad.
There should be enough room under the pulley for the pry bar , but watch as you are hitting the shaft so you don't bend the pulley. Even if you do bend it a small amount , you can fix it with a Crescent wrench or punch in a vise.
Old 05-08-2015, 08:02 AM
Power blaster, a press and maybe some heat.
Old 05-08-2015, 08:06 AM
TigerCub's Avatar
The pulley comes out the bottom?
Mine:
My Dad's:
Old 05-08-2015, 08:11 AM
As you are prying up on the pulley and hitting the shaft with the socket , the pulley will slide up the shaft.
If you know someone with a press , maybe they could take it off for you.
Old 05-08-2015, 10:15 AM
No, the pulley comes off the shaft from the top. If you have a press all you need to do is to support the upper part of the housing and press the shaft down since you already have the lower part of the housing removed.
Old 05-08-2015, 11:45 AM
TigerCub's Avatar
Ok, gotcha. I was worried when I seen that nut with the keyway inside, thought it was threaded. When I tear it down tonight I will take some pictures for reference and post in case anyone else needs.
Mine:
My Dad's:
Old 05-09-2015, 05:09 AM
TigerCub's Avatar
Here is the order of assembly, I took a 7/16 impact socket and placed over the shaft and tapped a few times with a 3lb. Hammer and the shaft/bearing assembly came out of the pulley.
Mine:
My Dad's:
