Old 05-02-2015, 09:22 PM
twingard twingard is offline
Default 2072 carburetor problems?
having some issues with my 2072...was mowing today everything was doin fine for about a half hour, then the motor started choking down...I shut it off, started it again ran for maybe 10 minutes then the same problem..this problem continued with no specific run time...may be 2 minutes might be 15......sprayed the carb down with carb cleaner that didn't seem to help at all..also no adjustments that I made to carb changed the problem....time for a rebuild? any other ideas? thanks for your time
Old 05-02-2015, 09:57 PM
CubDieselFan's Avatar
Did you take it apart to clean it?
Old 05-02-2015, 10:00 PM
no didn't get that far yet..jumped on the 1810 to finish cutting then got to dark to work on it
Old 05-03-2015, 07:29 PM
I doubt that it would. Spraying an assembled carb with carb cleaner does NOTHING.
This would be the next step.
Old 05-03-2015, 09:21 PM
drcjv's Avatar
drcjv drcjv is offline
I had the exact problem multiple times on 1872s. I cleaned several carbs rebuilt a few with varied results. The best results I got was taking the carb to the local dealer and having it rebuilt. 15 minutes off 15 minutes on and $60 later all was good.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 05-03-2015, 10:12 PM
KayakDon's Avatar
KayakDon KayakDon is offline
I had a Mercury outboard that sat 5 years with gas in the carb. Had the dealer ( my first motor boat)"rebuild" the carb.. slightly better. I talked to my snowmobile mechanic, and he told me to take apart the carb and boil it in vinegar and water for about 30 minutes. FIXED IT. He said he gets 100 carbs a year that need the same fix. You can spray them all you want with carb cleaner, but if you want to get every small nook and cranny clean, that's how he does it. Just a thought. Don
If it can't be fixed with a hammer,then it's an electrical problem
Old 05-03-2015, 10:21 PM
I had the same problem with my 1872. I use one of the 1 gallon cans with 3 quarts of solvent and the basket. It worked and I have not had any more trouble.
Here is what I used:
http://shop.advanceautoparts.com/p/g...m=carb+cleaner
Old 05-04-2015, 12:24 AM
That's the stuff
Soak it for a couple hours, or a few days, wash it out and use compressed air, rebuild. = clean carb
Old 05-04-2015, 01:03 AM
I read these threads all the time and I don't understand it. If the carb has been sitting for years and has dried up crud and rust in it, I'll soak it. If it's off a runner that suddenly "gunked up", or one that has ran in the distant past (6mo-1yr) and has gas in it, I just pull it apart and rebuild. Never had any issues getting one cleaned out of the first try.
Old 05-04-2015, 07:37 AM
mickb72 mickb72 is offline
I've saved two crusty cruddy carbs on the stove with vinegar and water. Then add sugar,pickles and peppers. I used to have a 115 merc, inline 6 with 3 carbs. Mike
