Old 04-30-2015, 07:02 PM
782CC 782CC is offline
Default My new Haban deck
Picked this up recently with the 2082. Really excited to get this one up and running. Impressive decks. Found cracked welds and severally bent/cracked rear mount. Looking around I found SamMac repair info. Sam Mac - Is that short for Mac Daddy? Did yet another one of his repair suggestions. (Thanks again Sam for all you give to this site) Was easy fix. Pulleys are bad so will be replacing bearing and will be ready to mow. Oh, welds aren't the prettiest but will hold.
Old 04-30-2015, 07:13 PM
Lookin good. I added a gusset on the back of my deck think it will prevent it from cracking again. Did one on each side.
Old 04-30-2015, 07:17 PM
This is where I got my bearings.
VXB.COM 1-800-928-4430
8 Bearing 6205-2RS 25x52x15 Sealed Ball Bearings
Price: $31.37
Code: Kit487
http://www.vxb.com/page/bearings/PROD/Kit487
These are sealed bearings so remember to remove the seal on the inside so that you can grease them.
Old 04-30-2015, 08:14 PM
I missed the gussets. Wondered what I wanted to do there. Missed taking pics, but did grind out the cracks then filled so I have a full fix of the metal. Bearings feel good so might run until winter. Here is a shot of pressing the plate straight. Some welding was outside and the wind picked up. Tig did not like that.
Back to the grinder and welder.
Old 04-30-2015, 08:33 PM
Sure wish I had the time to make my deck look like that! Think I will order bearings for when I do go into it. I saw wheel improvements also. So may go into that this winter as well.
Old 04-30-2015, 08:47 PM
Your doing a nice job on it. Considering how old these decks are and the beating that most of them got they are a pretty well designed piece. A little TLC and a few new bearings and they should be good for another 20 years. Thing will probably outlast me.
Old 01-29-2018, 08:38 AM
samckitt samckitt is offline
Price: $31.37
Code: Kit487
I know, old post, but curious, forgive me if dumb question. If bearings are sealed, how is grease getting to them from the grease fitting on top of shaft?
________________________
Scot
Old 01-29-2018, 09:40 AM
Grease exits the shaft in the center between the 2 bearings. The shaft is rifle drilled.
Old 01-29-2018, 10:11 AM
I get that, but if bearings are "sealed", then grease won't get into them.
Scot
Old 01-29-2018, 10:53 AM
Terry C's Avatar
Terry C Terry C is offline
Remove the seals that face inward. I also packed the bearings first. Make sure you clean out the old grease from the drilled hole in the shaft.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
