Old 04-27-2015, 12:04 AM
Nightow1 Nightow1 is offline
Default 147 Fan ?
Never owned a 147 before, It has some bad vibration when driving it, to the point of my but going NUMB! I noticed the fan shroud was loose , fixed it, then that the Fan will spin on the drive shaft??? What I mean is that if I hold the shaft I can spin the fan with my hand, The pin seems to be in there still and the fan is spinning on the section after the pin, if that makes any sense. Also since I have it apart, IS there anything else I should be looking to fix or replace for Preventative Maintenance???
Old 04-27-2015, 12:09 AM
Flex Disc joints, bent driveshaft, bad couplers, input shaft seal leaking.
Old 04-27-2015, 12:14 AM
Ok so basically the whole darn GT lol.
Old 04-27-2015, 12:15 AM
No, just the drivetrain.
Old 04-27-2015, 11:09 AM
SpringSpecial53 SpringSpecial53 is offline
Smile 147 Vibration
If you get the engine out and turn it over, you might check to see if someone has removed the balance gears. The 147 was the first Cub to have balance gears in it. The balance gears turn on needle bearings and these tend to wear. If they get worn enough they can come loose and cause major damage. To prevent this some people just remove the balance gears. I purchased a 1650 that the balance gears had been removed from and it vibrated just like you describe. I would be inclined to think that is what was done to your tractor. My personal preference is to retain the balance gears (Kohler put them in there for a reason) and just install new needle bearings (which are available). Most of these tractors have a lot of hours already and typically have made it this far with their balance gears still in. Therefore if you rebuild them to original spec., they should run a long time with balance gears and be a lot smoother.
Old 04-27-2015, 11:13 AM
Most anyone who rebuilds these engines will disagree with you. They are unnecessary, and a grenade waiting to go off. Removing them causes no harm and no matter what anyone says it doesn't change the engine vibration that much. I severely doubt that his engine has anything to do with a vibration like was described. Bent/misaligned driveshaft is most likely the cause.
Old 04-27-2015, 01:21 PM
Terry C's Avatar
Terry C Terry C is offline
Jmech is correct as usual. My 149 does not have balance gears and my 129 does
I can't tell any difference.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 04-27-2015, 01:27 PM
Terry C's Avatar
Maybe your rubber mounts are shot
Terry
3225
Old 04-27-2015, 02:01 PM
mortten mortten is offline
And I don't think the 1650 ever had balance gears. I haven't seen them all but I never saw an AQS with balance gears
Old 04-27-2015, 02:58 PM
How hard is it to remove the Balance Gears?
