Old 04-26-2015, 04:39 PM
Dadenstein Dadenstein is offline
Default 149 s/g trouble
Hi guys, I have a ammeter on a 149 constantly reading discharge, as well as a horrible mechanical growl/ grinding noise. Is this a bad s/g and s/g bearing? I would just like some pointers before I drop some heavy change just guessing.
Old 04-26-2015, 04:41 PM
Is the noise coming from the S/G...???
Old 04-26-2015, 04:45 PM
As far as I know it is. And it isn't constant. It will stop for a second or two and then start again.
Old 04-26-2015, 04:49 PM
My best advice is...........Take the S/G to a reputable repair shop and have it tested and rebuilt if necessary.
Old 04-26-2015, 04:58 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
I check all wiring to make sure you don't have a short and check your grounds if ones Is loose it can do it
Tags
149, generator, starter
