I would be grateful if someone could post a pic or 2 of the right & left side
of the engine mounted in the frame. Up close. The side panel/ baffle that goes above the starter, where the coil mounts in particular. I should have took a few before the tear down, I do think the previous owner did a bit of his own engineering of the coil mount and it ain't right. ( to put it nicely) I'd like to go back like it should be thanks Dave
![]() 1976 Cub Cadet 1200 & 44A mower 1964 Cub Cadet 100, No Attachments at this time, I do have a cart to pull stuff around. |
Dave,
Here are photos of the right (coil-starter) side of my 1450 that might help you. Not much is visible on the left (air filter) side because the filter housing hides the carb throttle and choke cabling. But if you need a photo of that side without the air filter just post I'll try and get that done. |
Thank you very much Roy, thats just what I needed to see,
Dave
Here's the other side...
You guys are great. I really appreciate the responses
Exactly what i was needin Dave
