Old 03-22-2015, 08:39 PM
Feoe.RL Feoe.RL is offline
Default Need Some welding advice
Hi yall I have a quick question I'm certain someone on here can easily answer... the back part of my generator/starter has a tab broke off. Question is What type of metal is it and can it be welded/brazed back together or am i better off trying to find a new one somewhere? Thanks in advance and hope all of you had a great weekend. Go Duke!
Old 03-22-2015, 08:44 PM
i believe its cast aluminum, your best bet would be to find a new one.
Pap's 100
Restored 108
1211 Dual Stick
1050
It will either need to be tig welded or replaced.
Craig made a new one for his starter / generator
http://www.onlycubcadets.net/forum/s...ad.php?t=36647
Old 03-22-2015, 08:50 PM
Merk Merk is offline
I would replace it if was me.
My local NAPA store had a replacement starter end frame. Not sure what the part number is.
Project Uncle Dick
Cub Cadet 70
Old 03-22-2015, 08:53 PM
Thank you Tim and Jeff that was quick and helpful. Ill see if i can have it welded tomorrow. I'm planning on getting paint underway Tuesday.
Old 03-22-2015, 08:54 PM
Theres a NAPA not far from here ill take it over and check thanks Merk
Old 03-22-2015, 09:04 PM
If you get it welded, your going to have to remove the paint....
Old 03-22-2015, 09:10 PM
Man I can't believe I missed that thanks Jeff, that Craig is just too talented, awesome.
Old 03-22-2015, 09:11 PM
If i have to ill just repaint that piece separate later on. No one said this restoration job would be easy lol. Thanks J-Mech
Old 03-23-2015, 06:33 AM
mickb72 mickb72 is offline
Default c
Hello, and when you get it fixed, don't tighten those end bolts to tight. The adjustment bolt will hold the belt tight. Mike
