Old 02-19-2015, 04:33 PM
Default Should I try this??
A power steering, on a GT??? It says 800psi max......has 8" of travel EACH way.....price= free...
I was just thinking if this substituted for the tie-rod, with a piece coming off the back of the axle to mount...?? It was just an idea.
Old 02-19-2015, 05:16 PM
Looks like an outboard boat steering ram. Need more info.
Old 02-19-2015, 06:06 PM
thats exactly what it is Sam.....it is 21" long (total) .625" diameter ram with what looks like .25"npt fittings.....
Old 02-19-2015, 06:07 PM
gt383mag's Avatar
gt383mag gt383mag is offline
you would then need 4 tie rod ends one on each end of that cylinder and one at each spindle but it could be done. only reason i can see for doing this and not bolting on stuff made for it would be cause that part is free... and i always say anything free is worth saving up for
Old 02-19-2015, 06:39 PM
i was just thinking a helm joint on each end (as is already threaded) and connected to the knuckle the same way the tie rod is...the mount body would have to attach to a bracket with some sort of slot in it so that i could "float" forward and back (maybe 2" tops) right off of the axle so that it could still swivel with the axle...the tractor im thinking would be a 1975 monkey wards 16hp hydro, just because it has easy hydraulic capacity and lots of room (no oil pan in the way like the cubs) ...i just dont know if it would need a supply and return off of both sides and if i could tee it off of the steering spool valve..or if one line to each port would function as both, push for supply, then return fluid as pushed from other end?? like i said, just an idea at this point...i do have access to others, and the next size up...which is made for 150hp-300hp outboards.....
thanks guys...
mike
Old 02-20-2015, 09:19 AM
I was thinking of using an OMC ram because it had the valve built in. Plan was to connect one end to the frame and the other end to the drag link. I need to see what the cylinder looks like up close so far all I've seen are pics from the internet.
Old 02-20-2015, 12:14 PM
you want me to get you one like this Sam, or bigger??? price is right
Old 02-20-2015, 12:21 PM
If your going to use a cylinder like that, you need to look at how the big tractors do it. Much simpler than the way you described.
Red line is where the tie rod runs. Same thing on opposite side. A SGT uses a similar set up, and so do the Lo-Boys.
You don't need a bigger cylinder.........
Old 02-20-2015, 02:00 PM
If I do it I'm looking for something like this that has the control valve built into it.
Old 02-20-2015, 02:25 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
So which one are you going to it do?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
