Hello guys! Been a long time since I posted here but wanted to share the updates done to my 1650. This process began when the engine literally shook itself out of the frame. So far I have done the cradle mod, added rear 6-12 duals, front tri ribs, added suitcase weights, made a custom lower grille, began work on the engine and updating the wiring harness. The deck gauge wheels will be modified to fit with the duals. Hopefully when the weather warms up ill be able to keep a steady pace on the work it needs including paint and decals. Tell me what you all think and here are the pics!
1967 IH Cub Cadet 123 1978 IH Cub Cadet 1650 19?? IH Cub Cadet 682 |
Oops. Im not sure how the pics turned upside down. Mods if you can rotate them I would appreciate it!
Looks good! Like your seat, that's what I was thinking of doing. I have the brackets to connect the arm rest to the seat. I like the duals. The narrow tires look good.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
Looks good but there's to much space between the tires for my tastes, your dual adapters look like there for 10.50 wide tires.
Thank you guys for the kind replys! The seat is a replacement seat for the Farmall 06 and 56 series tractors and is very comfortable! I like how it looks and rode good with the narrow front tires before it was parked for repairs. The dual spacers are from xtreme motor works for the 6-12 wheels. I wanted a kind of row crop look just to be different lol and flipped the inside wheels backwards to change the spacing. Look at my avitar and you will the same duals in the "correct" spacing on my 108. If it wasnt so cold outside I would out there now doing more work on it. Once spring hits ill begin my paint and decal work and continue posting updates until then.
where do you get all those little suitcase weights??
I get all of mine from mid west super cub. They have three different kinds I think. Mine are the aluminum "fake" weights but all together its an additional 55lbs of weight to my tractor including the steel bracket I fabed up from scrap. I want to redo the bracket itself at some point but it works pretty good for now. Hope this helps!
I like the spacing, looks like a long axle 56/66 series you would see down here with rice and canes. I think a little taller tire might be slightly better for me, but I like it. I bet that seat is nice!
73 149, 73 109, 71 128 with sleeve hitch, decks for all with a 44C on the 149 as the daily mower. front blade and IH rock rake |
