Old 02-08-2015, 07:45 PM
cub cadet 72 guy's Avatar
cub cadet 72 guy cub cadet 72 guy is offline
Default Which rims do I use ?
The tire on my 102 blew out and it has 2 different style rims. I thought that maybe one type is for a different model. Which one would be correct
Old 02-08-2015, 08:47 PM
Narrow Frame tractors have a deep dish like the orange/rusty wheel in the pic, BUT the valve stem is on the deep side (I don't see a valve stem in the pic). Wide Frame wide wheels have the valve stem on the shallow side of the wheel.
Narrow Frames and Wide Frames alike could use the narrow wheels, can't tell for sure from the pic if the whiter wheel is wide or narrow (but I believe it is a narrow wheel).
Old 02-08-2015, 09:18 PM
They're both wide wheels
Old 02-08-2015, 09:51 PM
The white wheel looks correct. I have a pair with good tires, send me a pm if your interested
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-08-2015, 10:47 PM
Narrow Frame, wide wheels have the deep dish on the outside with the valve stem on the same side.
Wide Frame, wide wheels have the deep dish on the inside with the valve stems on the shallow/outside.
If the valve stem is on the side that is showing on the rusty wheel it is for a Narrow Frame tractor.
I'm not sure what that white wheel is, Narrow Frame wide wheels have the valve stem set back much deeper than that wheel.
Old 02-08-2015, 10:52 PM
homebuilt homebuilt is offline
the white one looks like what my 122 had on it.
