Thread Tools
Display Modes
Hey guys I am redoing my 100 and I was wondering if maybe there is an upgrade for the rear to make it top out at a higher speed ?
![]() Quote:
![]() What do you plan on doing with it that you want it to go faster?
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
I've not heard of one but if you are looking for speed hydros go a little faster than gear drives. Maybe put 123 stickers on it?
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
Midwest Super Cub makes overdrive gears for the reduction at the front of the trans. I believe they go as high as a 23% overdrive.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
They go much higher. 43% is the biggest one they make but it requires some grinding on the reduction housing. 23% is the largest one that you can install without modification.
Cubs are already a little spooky in 3rd if its not perfectly smooth, I couldn't imagine 43% more speed.
