Old 02-01-2015, 01:47 PM
OldSchool81's Avatar
OldSchool81 OldSchool81 is offline
Default Hydro relief valve
I am waiting on a rebuild for the relief valve on my 1250s hydro unit. Is it possible to use the manual one from my 127 until I get the rebuilt one back?
I understand that I would have to depress it to move the machine if not running. Or would I have to borrow both?
Old 02-01-2015, 01:51 PM
Yep no problem.
Old 02-01-2015, 06:04 PM
TIMCRUTCHER TIMCRUTCHER is offline
Can I change the valves in my 129 hydro and then not have depress them to move it?
I don't use my Cub. I just work on it and look at it. So far it's holding up very well.
Old 02-01-2015, 06:07 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Sure can.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 02-01-2015, 08:14 PM
Wish someone had told me that before I put it all back together
Old 02-01-2015, 08:17 PM
LOL.... you didn't ask!
Old 02-01-2015, 09:29 PM
Shrewcub's Avatar
Jon's right! Read your signature again, Tim! Lol
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 02-01-2015, 09:43 PM
If you are going from manual to automatic relief valves, then keep a heads up on parking it so it doesn't roll away!!
Old 02-02-2015, 03:12 AM
Thanks for the info guys. I was wondering what makes these valves tic. Are they more likely to go out under more demand from the pump/heavy use?
For instance i am trying to figure if it went out because i am plowing snow with the tractor now. This seems to put a lot more strain on the machine naturally. Opposed to cutting grass slowly on mostly flat terrain. Or is it a don't worry I will break eventually and you will replace me part?
Old 02-02-2015, 07:09 AM
The typical failures are:
Mechanical Type: Plunger that moves up & down rusts up. Some oil leakage.
Automatic Type: Leaking fluid out the top vent hole.
NEVER heard of a valve failure due to heavy use nor the internals breaking.
