Old 01-18-2015, 02:07 AM
thadscub's Avatar
thadscub thadscub is offline
Default Fixing fuel line leak
hi guys i have a leak starting at the rubber sleeve at the carberator end where it attaches to the 90 degree would it be better to change over to rubber fuel lines or replace the rubber sleeve if it is better to change over to rubber line what thread is the elbow into the carberator
thanks thad
Old 01-18-2015, 07:58 AM
Oliverpuller's Avatar
Oliverpuller Oliverpuller is offline
I found small fuel line and cut my own ferrules from that for the stock steel fuel line compression fittings.
1961 4 digit Original; 1963 100; 1964 70; 1971 86; 1974 169; GT3100; #1 Cart
Old 01-18-2015, 09:13 AM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
I did the same for my daughters original. All you do is slice off a small piece of the proper diameter fuel line with a razor blade and you will have a fuel sleeve. It worked for me. If you want to get rid of the hard line I believe the fittings are 1/8" pipe threads. Size may depend on what model tractor your working on.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 01-18-2015, 09:16 AM
danfeste danfeste is offline
I do the same thing, I use 1/4 fuel line and cut it in 1/8" sections. Its a pretty tight fit, I put the fuel line nut on the steel line and then slide the piece of 1/4" line down into the nut. Usually I have to use a small screwdriver to get it to fully seat in the nut and make sure its square.
Collection: 100, 71, 128, 169, 582, 682, (2) 782. 1980 Scout Traveler Diesel.
Old 01-18-2015, 09:58 AM
I also just use fuel line and cut my own, you can make a lot with a foot of line which is usually the minimum the parts store will sell.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-21-2015, 11:56 PM
thadscub's Avatar
thanks guys, It looks like there is 1/4 inch fuel line in my future.
Old 01-22-2015, 08:14 AM
CSXengr's Avatar
CSXengr CSXengr is offline
Default Fuel line
I have the same problem and my local shop guy sold me fittings that I am not happy with. I need to get him on this site!
CSXengr
_______________________________
124 w hydro lift, 124 creeper gear, 125,126,128, 129,147 electric lift, 149 w/tiller, 1200, 1450 dual 1650 w/tiller control hydro, #2 Cart, Haban sickle mower, Gannon, 17 cubic inch cart.
