Old 01-16-2015, 09:46 AM
CubCadet129 CubCadet129 is offline
Smile 129 carrier
I have a question, did the cub cadet 129 with external brake cast iron rear end come stock with a thick or thin carrier and coarse spline or fine spline axles.
Thanks
Kyle
Old 01-16-2015, 05:40 PM
My 129 has the coarse splines.
Old 01-16-2015, 06:34 PM
My 128 has coarse splines and a rear end.
Up to 534 and counting...
Old 01-16-2015, 07:30 PM
kostendorf's Avatar
Talking
I'm guessing auto correct didn't like your rear end.
Old 01-16-2015, 07:36 PM
No,I am just being silly,meiwmciwqervierm
Old 01-16-2015, 07:43 PM
Pretty sure that the first fine splines were in the aluminum rear ends. So.... the late '82 series. AFAIK, none of the CI units had fine spine.
Old 01-17-2015, 09:20 AM
Ok guys thanks for all the info!!
Old 01-17-2015, 09:26 AM
Smile
Also one last question is that stock coarse spline axle setup strong enough wor snow plowing, light stock class pulling, and medium to heavy yard work?
Old 01-17-2015, 10:39 AM
Yes it will be fine but I would avoid taking a hydro tractor to tractor pulls, if you want a puller get a gear drive.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-17-2015, 11:29 AM
Your not going to tear up coarse splines. Olds is right, stay off the track. If you want a puller, you need a gear drive.
