Old 03-31-2010, 03:14 PM
the grump the grump is offline
Default shear pin?? size??
Cub 149 14HP cast iron Kohler. sheared the drive shaft pin near the motor. what size/grade bolt?? What do I use for a replacement?? Thanks in advance.
first post!!!! got the tractor apart down in the garden. gotta get it fixed and finish my work.
the grump.
Old 03-31-2010, 06:17 PM
redwaycc's Avatar
redwaycc redwaycc is offline
1/4" x 1 1/2" dowel pin, IH-19837-R1.
100(2) 128, 129, 76(1/2)
Old 03-31-2010, 07:15 PM
Amigatec's Avatar
Amigatec Amigatec is offline
This is what happens when you use a bolt instead of a pin.
Pat Benner Haskell OK
Old 03-31-2010, 07:27 PM
redwaycc's Avatar
and then you break out the welder and fix it like this......
welcome to OCC grump!
Old 03-31-2010, 09:00 PM
thanks fellas,
i looked up the part number IH-19837-R1 redway, thanks. that looks to be a solid pin. i put a soft, grade#2, 1/4" bolt in the driveline to get it back up to the shop.
i'll switch it out tommorow. thanks again.
the grump.
Old 03-31-2010, 11:13 PM
Lmercer Lmercer is offline
I never had any luck with those pins. I even bought a new slotted collar, driveshaft and I would still snap pins. I have a crossbreed 1650 with a 10HP in it and was using the wrong driveshaft for the 1650. I was using the same setup that Amigatec has pictured.
When I switched to the 1650 set up, there isn't any 'kickback' in that slot, 'cause there isn't a slot.
If it keeps breaking, I would think about doing something different.
Old 03-31-2010, 11:20 PM
Lmercer-
The reason you were breaking all of those pins was because that is the wrong driveshaft for a 1650. That hardened pin doesn't like to flex, and trying to make it act like a flex coupler on a rubber mounted engine is just going to make it break.
Old 04-01-2010, 12:00 AM
Lmercer-
Thanks Matt. If I understand you right, you only use that set up on a solid mounted engine?
Old 04-01-2010, 12:30 AM
Yep, that's exactly right
