Old 01-12-2015, 04:40 PM
Default Chains loosening?
After today's snow cleanup I noticed that one of my tire chains are loose. Not to the point of them falling off, but enough that I can pull the circumference chain out about 1-2" from the tire, and the opposite side I cannot do this. I do not run any chain tighteners on the outside of the wheel; I've never needed them. I was thinking the tire may have lost pressure to cause it to be loose, but it is at the same PSI as the opposite tire, and the chains are tight on that side.
Keep in mind these are 3 season old chains and they were new when I got them. They are tightened at the same link equally. Normally I jack up the rear end, let the air out of the tire, put the chains on tight, then air up the tire again. So far it's holding for one wheel but not the other.
When chains get used, it's it normal for them to wear and loosen like this?
Thanks for your help.
Old 01-12-2015, 04:57 PM
Just tighten it up and go!!
Up to 534 and counting...
Old 01-12-2015, 05:08 PM
I do pretty-much the same thing that you do, I put my chains on, then load my tires and then put the air to them.
I run loaded turfs and chains all year round on at least 3 of my tractors, I usually have to put a couple pounds of air in each tire when it gets cold. I've never had a chain "get loose" enough to need anything (other than those couple of pound that I mentioned earlier).
So the long answer is, no, I don't notice any wear to make the chains loose.
You don't have a broken link somewhere or a bent "connecting link" do you?
Old 01-12-2015, 05:36 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Did you bungee cord your chains???
Plow blade
#2 Cart
QA36 snowthower
Old 01-12-2015, 06:55 PM
No bungees or springs. I thought the link on the backside could be bent or loose, but it doesn't appear so. It can't get caught on anything because it's taped over (on purpose).
Old 01-12-2015, 07:33 PM
Maybe you opened a weld on a link,
or they stretched a bit.
I would check that and if no problem tighten it another link.
I will not use bungee or springs, not the right way to install chains.
Old 01-12-2015, 08:31 PM
That's why I currently do not have any.....
thanks
Old 01-12-2015, 08:57 PM
crossingcrown's Avatar
crossingcrown crossingcrown is offline
I have had chains kinked when they are put on, do something like that.. Take it off and try it again.. What could it hurt??
I am broke, but I make it work!
Old 01-12-2015, 09:13 PM
Billy-O's Avatar
thanks
The chain tensioner (bungee) are optional. You could either love 'em or hate 'em. I have 'em and it saves me the trouble of pissing around out in the cold.
Plow blade
#2 Cart
QA36 snowthower
Old 01-12-2015, 09:34 PM
I'm going to try this tomorrow. Thanks
