Old 01-09-2015, 12:10 PM
neilh419 neilh419 is offline
Default Don't Forget To Check The Air Filter...
Hey all!
I haven't been here in a while, but the 1641's been running pretty good. had it stored for a little over a month. I put the snow plow on it Monday, and we had our first little snow, here in Northern Ohio overnight. I cleared my driveway, the neighbor's and my sisters. Toward the end it started hiccuping, and sputtering, and I would just adjust the throttle a bit. I started it back up this morning, and it was much worse. I had two spark plugs, and mine looked pretty bad, so changed them. It seemed a little better. Couldn't figure it out. I know my choke cable is broken, but it's never been a huge problem. Just have to open the top and push it back in. Well, the cable is seized completely, and the choke was partially open. I pushed it back in all the way, and she was running good. I thought all was well. A couple minutes later, hiccuping again.
Then I went to look at the carb. when i pulled the air filter off, it pretty much cleared up. I put it back on, searching, sputtering etc... so I took the air filter off, and cleaned the driveway. Runs like a champ. She just need some air! Now, to the store this evening for the new filter...
Old 01-09-2015, 12:14 PM
jimbob200521's Avatar
Stop off and grab a choke cable while you're out, too! Something so simple and cheap shouldn't be put off
-Ryan
Old 01-09-2015, 12:43 PM
Originally Posted by neilh419 View Post
I cleared my driveway, the neighbor's and my sisters. Toward the end it started hiccuping, and sputtering, and I would just adjust the throttle a bit. I started it back up this morning, and it was much worse. I A couple minutes later, hiccuping again.
Any chance you got some moisture in your air filter element and it froze (especially overnight) and stopped up your filter?
Old 01-10-2015, 08:50 PM
It is possible. I tried to clean it a little, but it was pretty filthy. Can't seem to find a choke cable nearby... Anyone know where I can order one? It's a '92 1641.
Old 01-10-2015, 08:55 PM
Any parts store...... They all keep choke cables on the shelf.
You can order one at any Cub Cadet dealer, or from the sponsors up top, CCC directly, partstree.com........
Tags
1641, air filter
