Old 03-30-2010, 12:03 PM
bridgewatertek's Avatar
bridgewatertek bridgewatertek is offline
Default Wish me luck
Ok, the 1450 has been soaking with MMO in the top and bottom of the motor for a week, time to try to break it loose. Wish me luck!!
Jim Bridgewater, KD0FJO Osage, IA
1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab
Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow
Old 03-30-2010, 12:26 PM
dads70's Avatar
dads70 dads70 is offline
should work ive used it on a 1947 chevrolet truck that had sat for 30plus years in a barn pulled plugs filled with it sat for 2 weeks tuned up new batt. she fired up smoked till rings seated again then worked fine GOOD LUCK
Old 03-30-2010, 12:29 PM
Good luck! Hope everything works out for you.
Old 03-30-2010, 01:20 PM
transformer transformer is offline
Good luck...It worked for me this week same thing.......
Old 03-30-2010, 08:30 PM
Well, THANKS A LOT guys. Your luck came through. I pulled the PTO off, put the pipe wrench on and turned it over with 2 fingers on the wrench. Original problem when it was parked was that I could not get spark. Problem solved. Points, plug, coil, condenser, and battery solved that problem. Now just need to rebuild the carb and drive it out from under the deck finally.
Old 03-30-2010, 09:21 PM
IAfarmer's Avatar
IAfarmer IAfarmer is offline
It's nice to have an easy fix every now and then. Congrats!
Old 03-30-2010, 09:32 PM
dads70's Avatar
Default awesome
congrats
Old 03-30-2010, 10:41 PM
Glad everything worked out, bridgewatertek!
Old 03-30-2010, 10:53 PM
Congrats....good feeling aint it....
