Old 12-22-2014, 11:58 AM
RedHawCadet RedHawCadet is offline
Default Cub 782 front axle on a 122
Dad and I got tired of the slop in the front end and wanted a better fix. So we decided to use a wide frame front axle. The wider tires out back will compensate for the wider front axle. Has anyone else done this?
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
Old 12-22-2014, 12:05 PM
I put a 1X8/9 front axle under one of my 122's.
If you use the correct wheels (for the axle) it ends up being the same width as the original N/F axle/wheels/tires.
Depending on this tractors intended use, wide rear tires and N/F front wheels and tires looks kinda cool too though.
Old 12-22-2014, 01:28 PM
chris hall's Avatar
chris hall chris hall is offline
I did the same on my 105. I used wider wheel in back so the front wouldn't look odd. I also upgraded to 1250 lbs trailer hubs .
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀.
Old 12-22-2014, 09:41 PM
Can you turn the front wheels "in"??
Old 12-25-2014, 09:15 PM
Tim.E's Avatar
Tim.E Tim.E is offline
Yes,Turn your front wheels around or use narrow front rims.
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 12-26-2014, 10:49 PM
Even with a 1" axle?
Mark
QA42 snow thrower
42in front blade
