Old 03-27-2010, 05:26 PM
57130's Avatar
57130 57130 is offline
Default What Hydro Fluid?
I'm working on maintaining my two hydrostatic Cub Cadets, 1450 and 149. It's time to change the hydrostatic fluid, and I was wondering what type of fluid you guys used. Do you use the IH Hy-Tran or some equivalent. Also, when you change the filter and fluid, do you have to pop off the rear differential cover or not? When I got my first 1450 it didn't need anything but a topping up, and I didn't use it a lot because I was working on it and didn't know it's usefulness. Now it's time, so I need to figure it out.
Old 03-27-2010, 06:13 PM
Hytran Ultra, its the only stuff that absorbs water and keeps it from damaging the tranny. Yes, pull the cover , get a new gasket...It will enable you to clean all the gunk that might be in there .
Old 03-27-2010, 07:25 PM
Ditto what truckntran said
Old 03-28-2010, 12:25 PM
57130's Avatar
Thanks guys, that was everything I needed to know. Hopefully, I can get the parts I need this next week.
Thanks
Old 08-10-2010, 01:10 PM
CHolmes CHolmes is offline
Why is it when you have a Sunstrand in a Cub you must use International Trans and when you have the same trans unit in a JD you must use JD oil? I think if you look closely all the dealers get there oil from the same place. Check the MSDS for the product and it will give you the supplier.
Old 08-10-2010, 01:14 PM
Hytran has moisture absorption properties that the other fluids do not. I have had several rearends that I drained WATER out of because they sat outside, yet because there was Hytran clinging to all of the parts inside, there was no rust at all. I have not seen any other fluid do that.
Old 08-11-2010, 04:01 PM
Tim S. Tim S. is offline
Are these two fluids the same thing in the picture above?
Old 08-11-2010, 04:20 PM
They are the same. The gallon jug on the left is from an IH and is about $16 a gallon and the quart on the right is from a Cub dealer. I think it takes 1 and 3/4 gallons to fill a hydro.
Old 08-11-2010, 06:15 PM
Also, if you have multiple tractors, the cheapest thing to do is go to a Case-IH (or Case heavy equipment) dealer and get a 5-gallon pail. The more you buy, the cheaper it gets.
Old 08-11-2010, 08:09 PM
aagitch's Avatar
aagitch aagitch is offline
CHolmes, I've actually had a couple JD dealers tell me the same thing about their version of Hytran for our older hydros. I haven't used the JD brand but a few times and although I haven't noticed a difference after fluid changes I haven't used it enough to say if it's as good. As long as it's convenient I'd still stick with Hytran though.
