Old 11-30-2014, 09:10 PM
jubilee's Avatar
jubilee jubilee is offline
Default Refreshed the 54 inch mower for the 1782
This mower had large patches of paint missing and rust showing when I bought the tractor last year and I finally got around to fixing it over the past two weeks. New paint, spindle bearings, races and seals, four new wheels, new bushings and wheel bolts for the front, drilled out the spot welds and replaced the bearing in the idler pulley as Sam Mac described previously, bored out the two rubber rollers with a 7/8 inch paddle bit and inserted a piece of plastic electrical conduit to eliminate most of the play in them. The new belt will be installed tomorrow after I remember how to route it. The dealer I tried to buy the front wheel bolts from could not get the part to come up in his parts system. He thought I gave him a bad part number, but when he went to the Cub site he got the same number I had. So- I went to Lowes and bought two 6 inch long 5/8 inch bolts and went to my friends machine shop so he could make them. They start out as a 5/8 inch bolt for about an inch, then step down to 1/2 inch for another 2 or 2 1/2 inches and then are threaded for a 3/8 x 16 nut on the end.
The leaves are falling pretty well now so I am looking forward to killing them with the mower. It does a great job on them and I don't own a leaf cart like some people in South Carolina do.
___________________
Jim
782 w/Command 18,
1862 not running;
IH 42 inch blade; off brand cart
Old 11-30-2014, 09:13 PM
jubilee's Avatar
I meant North Carolina!!
___________________
Jim
782 w/Command 18,
1862 not running;
Old 11-30-2014, 09:54 PM
jubilee's Avatar
.I will try to post before and after photos.
___________________
Jim
782 w/Command 18,
1862 not running;
Old 11-30-2014, 11:21 PM
gdheck's Avatar
gdheck gdheck is offline
Good job on the deck. I sure wish the plastic on it's older brother was that nice when I bought it.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 12-01-2014, 08:06 AM
Deck looks great. Maybe this will help with the belt install. Crazy looking routing.
Old 12-01-2014, 08:24 AM
That mower has a simple belt routing compared to this one;
[IMG][/IMG]
The above mower has two idler pulleys,
Try to figure out where the belt is going, it is a challenge
Old 12-01-2014, 10:02 AM
jubilee's Avatar
Thanks for the inputs guys.
gdheck-I had to replace the nose plastic when I brought the tractor home and still need a new right side panel. That one is bolted together at the cutout, but it works, so I'll look for a replacement one of these days.
SamMac- Thanks for the belt routing illustration. I thought I had printed off that illustration early last year when I had a reason to put the belt back on it, but I couldn't find it yesterday.
CADplans- That belt drive needs to stay in your yard!
___________________
Jim
782 w/Command 18,
1862 not running;
