I was going to take my Dash tin off for some well needed rejuvenation, but how does the hydro control lever come off? Is there a set screw in it...I can't see it that well my freeking eyes don't work like they used to!
"We don’t stop playing because we grow old, we grow old because we stop playing." ![]() |
There's a set screw in it, its under were the lever sticks out.
Thanks Tim I thought that's what it was...but I need to make a trip to the eye doc and get some new lenses. No matter how much light I put on it I couldn't tell what it was
Maybe it is not in there,did you try using the correct allen wrench in there?
You can feel around in there for it.
What model tractor?? Some of them screw off and on Ya know, the knobs on the levers I mean!
No!!!.....Wait!!!!, NOW I know how I ended up with so darn many of these things!!! I swear there was another one in my storage shed last time I looked! |
I believe it's a 149
Steve
They can be a PITA to get off. I managed to get the set screw out of mine but the splines on the inside of the lever had worn so I ended up drilling a hole through the top of the lever, put a socket head bolt through the hole and used a puller to get it off. When I put it back together I drilled through the set screw hole, the shaft and out the other side of the lever and tapped it for a socket head bolt. Not pretty but it works.
Thanks for posting the "picture story". I have not had to remove it from my 149 yet. But, the tin needs replacing. So, eventually....
Steve |
![]() Quote:
