Old 03-25-2010, 09:15 PM
cub149's Avatar
cub149 cub149 is offline
Default removing rock shaft from 149
Well, I wanted to remove the rock shaft from my parts 149 and put it on my running 149. How in the h...l do you get the roll pins out? I can't get a straight shot on them from the top. The bottom of the frame has some holes in it right at the pins but it is still not a straight shot. Anyone done this?
While I'm at it. I pulled the cover on my 149 to drain the fluid and to replace the cork gasket on the hydro pump. This is the first time I have changed the fluid on this one and when the cover came off I found that part of the rear housing was chipped out at one of the bolt holes (lower right bolt, you can see the sealant around the hole). The PO had filled it with silicone caulking. It never did leak as the very outside edge is still intact. I am putting a sleeve hitch on it from the parts tractor, now it looks like I will be putting the rearend from the parts tractor in also. I will be keeping the pump from the running one, it is very strong.
Chip T.
Drexel NC
Old 03-25-2010, 09:40 PM
redwaycc's Avatar
redwaycc redwaycc is offline
my 128 and 129 had/have cotter pins so it was/is a none issue. the only thing i could suggest is pull the engine and then swing the rock shaft down, towards the steering column, and you would then have a straight shot.
100(2) 128, 129, 76(1/2)
Old 04-03-2010, 10:55 PM
brad121075 brad121075 is offline
Just got my first cub 129 on Wednesday. Is the rock shaft the implement lift shaft? i just changed the roll pins in mine.....
Old 04-03-2010, 10:58 PM
There should be spirol pins in the rockshaft, not cotter pins. I'm surprised you haven't sheared any off.
