The pulley on the back of the thrower unit that runs off of the clutch. loosened up allen screw and the pulley was rusted on the shaft. tried liquid wrench soak and heat from propane. did not budge. tried a 3 jaw puller and SNAP the pulley ridge is now broke.
![]() what part number and where is the rout to go to replace? PS I have a NEW IH belt, so a "close" pulley from Northern Tool or a place like that makes me nervous. hope NAPA has a close substitute if someone has done this, please let me know part number thanks
![]() ![]() Cub Cadet 108, IH snowthrower, IH ?? mower deck Cub Cadet 1650, IH 44 mower deck, IH snowthrower 1960 Cub LoBoy- yellow roundnose. Fast hitch w creeper and roto tiller, front blade, mower deck and Fast hitch one bottom plow and rock rake 1951 F Cub with Wagner loader and woods brush hog, 152 disk plow and 23A harrow 1953 Ford Jubilee tractor and F100 Pickup
Do you mean a QA36A? And what tractor are you putting it on. It matters, as there are different pulleys available.
Post a pic of the damaged pulley. It may not be unusable. Did you get it off? |
Correct I meant the QA36A. It's going on the my 108 ( it came with the tractor from the previous owner who had it 20 years) this is also the tractor with charging issues I am looking into..
The pulley shattered when I put the jaw puller on it. it came off the shaft tho with more "coaxing" after that. shaft measures .75" bore on pulley, and the pulley outside diameter looks to be 4.5'. My cadet belt is 30 inches long for it.
You can give our sponsors a click or call on top of the page.
To remove the 4" OEM iron cast pulley of my QA42A from the shaft I first try a mix of 50/50 Acetone/ATF oil with no success so I heat the iron cast pulley with Methylacetylene Propadiene Gas (MPS) and the puller remove the pulley with ease after that. Propane gas alone don't produce enough heat.
You need a "iron cast" replacement pulley, no aluminum cast crap! Best cheap solution is to machine one on a lathe but if you own this kind of tool you already figure this out.
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
I stopped at Fleetfarm last night and bought a steel "make your own pulley" setup
4.5" wheel with a center hole missing for the steel "pick you own bore" insert welded to 2 together and basted the shaft with "never seize" before putting it on we will see how it holds up
That will get you going but the pressed sheetmetal pulley @ TSC, is just a step above Aluminum, --not good in a hard pull.
Take the time to look for a good cast iron or solid steel pulley,(or spoked is ok) it will not cause you a problem later on with splitting apart. I took the time to give you some good examples in prevous post. Best of luck. |
Try McMaster.com
Search for iron pulleys. Prices are reasonable (imo) and they ship fast. |
