Old 11-10-2014, 12:26 PM
TheSaturnV's Avatar
Default NF Driveline U-shaped Screen: 2 sizes?
Hey all.
This is on my 147 with original K321:
Trying to reinstall the screen/cover and the one I sourced online will not fit in the remaining space between the dash mount and the engine. Did these buggers come in different sizes over the years?
Thanks!
Old 11-10-2014, 03:14 PM
Apparently, there are two. The one for the 147 must have been specific to just that machine. It doesn't list a part number for it in the online parts book, just that it is NLA. All other machines I looked up they are still available, and carry the same part number. My guess is, it's narrower for the 147 because of the larger motor. I'd suggest modifying that one to make it correct, or trying to locate a NOS, or even a used one. If it was mine.... I'd cut that one down, repaint it and make it work.
Old 11-10-2014, 05:35 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Does anybody know why some tractors used solid clutch covers and some used screens? Was it a hydro/ nonhydro thing or something else? My 1X2's are different. I can't recall at the moment which ones have what. I was curious which was correct?
OP I would also do the same as Jon.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 11-10-2014, 06:01 PM
TheSaturnV's Avatar
Apparently, there are two. If it was mine.... I'd cut that one down, repaint it and make it work.
Thanks J-M. I thought I was going crazy [short trip] because I'm pretty sure I didn't shrink the frame during my refinishing!
I think the fastest way to get to the goal is to cut the one I have down, but easier said than done. If I had a big ol' chop saw with a metal blade it might be doable, but I don't have one.
Anyone think of any slick ideas how to shave 1/4" or so off without crushing the thing, and leaving a nice clean edge at the same time?
Old 11-10-2014, 06:56 PM
yes they are smaller,3.5 inches,I have one on my 147
Old 11-10-2014, 06:59 PM
Saturn do you have a belt sander?or access to one of the stationary belt sanders? Scribe a line and get close with a cut off wheel maybe and go the rest of the way with the sander with coarse paper. I would think using any kind of saw would rip it and be unsafe unless you can clamp it and use a body saw. Just a brain storm.
Old 11-10-2014, 07:46 PM
bolivier's Avatar
bolivier bolivier is offline
I'm thinking an air cut off tool, then some sort of sander to clean up the edge. Just like Alvy said. I definitely wouldn't try to cut that in a chop saw. Just asking for it to sling out.
Old 11-10-2014, 07:48 PM
even a set of tile nippers would work.
Old 11-10-2014, 08:55 PM
kostendorf's Avatar
These will work great with very little bur work.
http://www.harborfreight.com/3-inch-...ter-47077.html
http://www.harborfreight.com/pack-of...tal-44812.html
Old 11-11-2014, 04:19 PM
The earlier tractor had a solid sheild and the later had the one with holes, I assume they did this to allow the engine to draw more fresh air and to vent the clutch.
Pap's 100
Restored 108
1211 Dual Stick
1050
