Old 11-05-2014, 07:28 PM
IH_147's Avatar
IH_147 IH_147 is offline
Default QA-42a question
Hi y'all I've been thinking about buying a qa-42a for my 782 and i was wondering if the horse power will help blow wet snow because on my 147 it would clog up and slip would this happen with this blower? any advice will help thanks
100,122,126, 126, 126, 147,147,800,127, 982, 1210, farmall 300, farmall 560 diesel
Old 11-05-2014, 07:30 PM
yes it will,wet snow is hard on any single stage thrower.
Up to 530 and counting...
Agreed lew.
Old 11-05-2014, 09:51 PM
Mike in SD's Avatar
Mike in SD Mike in SD is offline
I have a QA42A on my 682, it works great. The larger belt also helps to get the power to the blower without slippage also.
Mike
Old 11-06-2014, 03:42 PM
IH_147's Avatar
what belt size should i use mike
Old 11-06-2014, 03:53 PM
The one is calls for. What Mike is saying is the '82 series uses a larger belt than the 147. You will have to change the pulley to work with your 782.
Old 11-06-2014, 05:52 PM
Mike in SD's Avatar
Yes what J-Mech said. Along with changing the pulley on the blower you will need to change the top lift arms to curved ones, so the blower chute clears the gille.
PT# CC-82-001 bottom of the page on the snow blower parts page.
http://www.xtrememotorworks.com/Part...rts%20List.htm
