Old 11-04-2014, 11:11 AM
kostendorf's Avatar
Default 1650 steering upgrade
I've been reading the 1250 upgrade thread and have a few questions of my own. I had tight spots in the steering column after I changed the adjusting screw and figured the worm gear was worn so I purchased a column out of a 1050 which is a ccc 703-1085. It seems to me this one is built better than the one I took out which has Ross-10200 7 stamped on it. The 1085 has a solid shaft and a larger adjuster. What I want to know is was the Ross one the correct column for the 1650 or a replacement from something else?
Old 11-04-2014, 08:58 PM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
As far as I know all the steering columns of this style are built by Ross.
107 with rear lift
1250 hyd lift. 682 diesel project
Original project
#2 and tiller
#2 trailer
59M sheader
home made boxblade
wideframe 54" snowplow
