Old 11-01-2014, 09:32 AM
blee128 blee128 is offline
Default 128
I'm trying to buy a 128 and the guy that I have been talking to, is including a 126 for parts. He says the shifter on the 128 is broke but made a comment about replacing the rear end. So my question is, will a 126 rear end go in a 128 without anything special ?
Old 11-01-2014, 09:44 AM
Most times it is easier to weld the broken shifter on the 128,,,, I have done two, is is REAL easy!!
BUT, if the machines have the same type brakes, the entire trans can be swapped, also.
That is pretty easy, too!!
Oh yea,,,,
Old 11-01-2014, 10:27 AM
The rear end should swap right in but the shifters are different, I'd pull the shifter out of the 128 and we whats up because you might just need to weld it or buy a new shifter.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-01-2014, 11:01 AM
Ok then it looks like there might be some duck tape around the grip and the shaft of the shifter so I might actually just need a new grip for it but the guy isn't making sense so who knows
Old 11-01-2014, 11:33 AM
Merk Merk is offline
There is information on how to repair shifter in tech section
Project Uncle Dick
Cub Cadet 70
