Old 10-31-2014, 12:48 PM
Default Tiller mule drive pulleys
A while back some of you were looking for solid steel 4" pulleys for your mule drives on tillers. Just found these on Surplus Center.
http://www.surpluscenter.com/Power-T...Y-1-3746-A.axd
Old 10-31-2014, 02:03 PM
kostendorf's Avatar
Thank you Sam Mac, That would be $57.00 for me. Not bad for 2 HD pulleys with a changeable bearing.
Old 10-31-2014, 04:11 PM
One thing, you may need to do is have the bushings that fit in the center of the old pulleys turned down to 1/2" OD, the factory stuff has a 5/8" OD and a 3/8" ID. Should take about 2 minutes in a lathe. Or maybe you can find the proper size bushing. Other option would be to drill the parts that the 3/8" bolts go through to 1/2". That's probably what I would do if it were my tractor.
Old 10-31-2014, 04:26 PM
The cub ones are 3"dia, so you need a longer belt, easy peasy
Up to 534 and counting...
Old 10-31-2014, 05:20 PM
kostendorf's Avatar
Your right, the mule drive I have has 3" pulleys. I went looking and found this... does it look heavy enough? Actually these are what I have now.
http://www.lawnmowerpartstore.com/se...ley-for/Detail
Old 10-31-2014, 07:10 PM
those do not look heavy duty,
Maybe Sam has a link to another size in that site?
Old 10-31-2014, 09:03 PM
kostendorf's Avatar
It took me almost 2 hours to find out what diameter IH-493164-R91 is.
I bet Jef could make these.
Old 10-31-2014, 09:31 PM
It took me 5 minutes hehe,
i have one.
Old 10-31-2014, 09:47 PM
kostendorf's Avatar
Do you need another one? I don't want to buy just one.
http://www.ebay.com/itm/New-Cub-Cade...item5411058ee4
Old 11-01-2014, 05:54 AM
i have one.
Lol Lew.
