Old 10-29-2014, 11:03 PM
Guitar Guy Guitar Guy is offline
Default Any thoughts on the 682?
I'm looking at a 682 for sale, serial # 667XXX.... in the $700 range, which seems a little steep, as it is in average used condition. Haven't looked at it in person yet, he said it runs well, and the hydro & everything else functions as it should ..... 50" deck included.
I currently have a Quiet Line 1000. Can anyone tell me if the 1000 wide frame decks, wheels, and snow blade will work on the 682?
Any thoughts in general on the desirability, value, problems, things to look for, etc., with the 682? Any info. will be appreciated.
JT .... also: I think that serial # is 1980 - 81. Can anyone confirm that?
Old 10-29-2014, 11:11 PM
bolivier's Avatar
bolivier bolivier is offline
Wheels are the same. Deck is the same except the center pulley. The 682 uses a 5/8 belt, where the 1000 uses 1/2. Jimbob put a wide frame snow blade on his 1863/64. Can't remember which it is. He said it worked, but I think he had to trim something. Check out the threads he started and you will find it.
The 682 is a nice tractor. It does have the manual lift. After having tractors with hydraulic lift, I'm sold. I'll keep my 100 just because it's cool, but for any real work I use a tractor with hydraulic lift.
Although, if all you are going to do with it is mow, I don't think it will really matter. Decks aren't that heavy to lift.
$700 seems a bit much unless it's a pretty nice tractor. Maybe really nice. It could be 79-81.
Old 10-30-2014, 06:55 AM
jeepchicken5000's Avatar
when I was first buying tractors my 682 was my second one after the 123, I had that for over a year did hardly anything to it other then the oil and hydro fluid, it came with a 50 inch mower deck and I paid $450 for mine now wasn't the best had holes in the deck but it ran and drove decent, after using it to mow the lawn it did seem to use oil never really saw any smoke but now and then you did. I since sold it to my neighbor and he loves it drives all over town with it, the fuel pump is bad and I told him but he wont listen and he had to do a hydro valve as it went bad. Other then that that's about it for 2 years of use between us. there great tractors but it just seems the KT engines seem to have more problems then the Kohler K series, at least all the ones for sale here locally do
1981 cub cadet 682
1966 cub cadet 122
Old 10-30-2014, 07:49 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
if you have a hilly yard or you mow a ditch and it has the series 1 KT you'll want to stay away from it. side hill mowing kills them
Old 10-30-2014, 11:25 AM
82 series are good tractors. They are personally my favorite styled machine. Brent was close on year, but since you didn't supply the last 3 digits we can't tell for sure. It's not an 81. Could be a 79 or 80 with the #667XXX number. That would make it an IH machine. Which is cool if nothing else. Don is right about the KT motor. I have a 682, but the engine was bad when I got it. It did run, but knocked. I pulled the engine and have a V-twin awaiting install when I get the time. If you get it a engine will more than likely be in it's near future. I hate to knock the KT's but their life is all about gone in most of them. $700 is way too much unless it has a replacement engine. (KT series II or a Mag, or even a V-twin.) Because of the almost guarantee of engine failure I don't want to give more than $350 for one of those machines. But, if it's nice..... your call. All your attachments that fit the QL you have will attach to it no problems. But, as Brent said, you will have to change the center pulley on your deck to make the mower work. All in all if you can get them down on price it wouldn't be a bad buy, and I say that without seeing it. Mainly just because I like those machines.
Old 10-30-2014, 11:38 AM
LOL, don't want to give more than $350? Jon, a nice original 682 with a nice 44in deck will bring $800 at least IMO, and that's because I have seen it. don't start like last time.
Old 10-30-2014, 11:54 AM
I won't tell you what I gave for mine then Nick. And it ran when I got it!! Mine is also a IH built machine and had 3pt. I didn't even give that for my 582 and the sheet metal and paint on it looked PERFECT, and came with a deck. It's all up to the buyer. Here's the big deal on a 682. More than likely it will need a motor. For a tractor that you know your going to have to drop anywhere from $400 to $1800 for an engine in, I just won't spend that much. Like I said, if the KT I has been replaced with a better motor..... then yeah I might give $600 to $800 depending on condition. Like I said, that's my opinion. Doesn't make it wrong.
Old 10-30-2014, 12:00 PM
Yep, understood, mine has the kt17 series 1 I think which is the "not so good" one, yea your 582 is nice , ccc built right ? Mine was IH and so is my 682.
Old 10-30-2014, 01:39 PM
jimbob200521's Avatar
OP: I agree with what was said above, but I'll also say this; I'm about to pick up 2 782's (one without a motor) for what John said he wouldn't pay above That being said, if it doesn't have a Series I and is in good shape, pay whatever you are comfortable with. The great thing about Cubs, at least now, is that there are always more out there
-Ryan
Old 10-30-2014, 02:00 PM
Series 1 are ok if you aren't mowing on hills.
