Old 10-28-2014, 09:22 AM
SS5150's Avatar
SS5150 SS5150 is offline
Default 86 taillights
What's everyone use for taillights on 1x8/9 & QL tractors? I was thinking 82 series tails or truck lite model 18s, but I didn't realize I'd have to drill through the fender. Is there anything low profile that's a flush mount ? I'm just concerned about my fenders rusting if I drill them. Anybody have a good source for a headlight switch? Thanks
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 10-28-2014, 09:43 AM
If you drill a hole just put a little grease or never seize on the bare metal and the will keep it from rusting. I used lights from tractor supply for mine and they look great and I think there brighter than the headlights.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-28-2014, 10:09 AM
I used LEDs from Grote on mine, lined up exactly with existing mounting holes but had to drill the center hole to clear the raised backside, they are Grote #47732.
Old 10-28-2014, 11:03 AM
SS5150's Avatar
I looked at the 47732s too, are they bright? How thick is the assy, could it get knocked off easily? Or broken?
RUN IN THE RED
1872 project
Old 10-28-2014, 12:55 PM
They are plenty bright, and are not much thicker than the OE reflector. Very low amp draw.
Old 10-28-2014, 11:02 PM
I use these from Harbor Freight. The price is right and no need to drill any additional holes. I have also seen the lens caps at various tractor shows in purple, green, pink, blue, etc. if you want a more retro '60's look.
http://www.harborfreight.com/red-cle...air-93227.html
Old 10-29-2014, 10:18 AM
Whizdbiz2 Whizdbiz2 is offline
My 86 (all original) doesn't have rear lights, just reflectors. It's yours to do with as you please but the 86 had limited production so not many of them in original condition out here. Guess there might be one less soon?
Cub Cadet 86
Mahindra eMax 22 w/FEL
Husqvarna LGT2554
John Deere GT275
'48 Ford 8N
'41 Ford 9N
Yerf Dog Scout CUV
Old 10-29-2014, 11:33 AM
If it came with out headlights it would have reflectors, If it had headlights it would have taillights.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-29-2014, 02:59 PM
darryljs's Avatar
darryljs darryljs is offline
I got these at Tractor Supply, same as Harbor Freight but cheaper. Used them on my JD.
Blazer Rectangular Dual Bulb Clearance Light Red
016511999 $4.99
http://www.tractorsupply.com/en/stor...nce-light--red
Patience is the key to success . The difficult, I'll do today . The impossible, I'll do tomorrow
Old 10-29-2014, 06:36 PM
016511999 $4.99
Those are what I have on mine pictured above.
Pap's 100
Restored 108
1211 Dual Stick
1050
