Old 10-28-2014, 05:52 AM
dbuck dbuck is offline
Smile Now have a 70
My Stepson delivered and gave it to me. He found in a scrap yard. This tractor is complete, with deck. Every thing on it is froze up. Engine is free and turns over by hand. Can someone advise me where the SN is? I taken pictures, now have to fiqure out how to post them.
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 10-28-2014, 06:09 AM
Click on this link.... Serial Number Locations
Old 10-28-2014, 09:02 AM
dbuck
Congratulations on the new 70.
Hope it turns out to be a great tractor for you
Old 10-29-2014, 03:26 AM
Smile
Mr. Bedell, Thank you. I guess I am have to remove the fenders, because, I looked at what I see of the rear end and all I found was a casting number.
Old 10-29-2014, 03:31 AM
Smile
dbuck
Diz Jr, Thank you. It has been a long time since I have had a gear driven CC,
all the rest have been hydros. I think the PO has install the wrong hood, as it is hitting the steering wheel upon closing. If I could get someone with a 70 to measure the lenght of their hood, It will be appreciated.
Old 10-29-2014, 03:48 AM
cubby102's Avatar
cubby102 cubby102 is offline
The hood is probably correct. They probably ran into something and bent the front of the frame where the grille mounts. Ive had luck with grabbing the top of the grille and giving a solid jerk towards the front to bring them back. Also have taken the grille off and persuaded it with a BFH till it was straight again
Old 10-29-2014, 09:25 PM
Merk Merk is offline
Odds are the hood has been push back. My last 100 that I purchase had the same problem. The frame is mess up a little where the front grill connects to the frame.
For a quick fix I put a washer between the rear grill mount and the frame. The hood now clears the steering wheel.
Project Uncle Dick
Cub Cadet 70
Old 10-29-2014, 09:31 PM
binderfever binderfever is offline
I recently got a 100 that does the same thing except if I turn the steering wheel a bit the hood will clear the wheel.
782D, 1450, 100, SO 76, 60, 102 puller, 3314 self propelled and 3323 push w electric start
Old 10-29-2014, 11:38 PM
Berwil's Avatar
Berwil Berwil is offline
That's the way my O is, just figured it was a worn out steering gear and dash grommet. I didn't think about the grill being pushed back, will have to check that out.
Bill
Old 10-30-2014, 09:32 AM
Smile
Thank you Fellows for all the replies. The front of the frame and the grill show no damage. Merk, I will try the washer trick. Am I correct in assuming that the washer will tilt the grill forward more? The PO cut a 2 inch section out of the outer cover on the steering wheel. My guess is hoping the hood would clear, did not work. Could someone give me some suggestions/advice on how to post pictures? Merk, I just read all the posts on your 70 restoration, when I get into this tractor, your restro will be a great help.
