Old 10-25-2014, 08:36 PM
Rob C's Avatar
Rob C Rob C is offline
Default 149 mower deck question
Recently purchased 149 with mower deck (serial num. of deck in pic). My question is...can the spindles for 50" deck be pulled completely apart and cleaned? Also, can the grease fitting be removed? I see no spot for a wrench on it..
Also..lol...Is there a good sevice manual out there for the 149?..OK, that's it for now
Old 10-25-2014, 09:09 PM
Here is the manual for your tractor
http://www.onlycubcadets.net/forum/s...ead.php?t=4644
Look in technical implement section but I believe your spindles are serviceable and the grease fittings are pressed in
Old 10-25-2014, 09:33 PM
Rob C's Avatar
Thanks for quick response! I didn't see that they were seviceable, but the sevice manual will be a huge help. Thanks a ton. The manual said to pull out of deck and inspect/replace as necessary... looks like ill be tryin them out as is... they spin, but, i hear/feel lots of grit from who knows how long they been sittin outside. I'll hopefully get to pump tons of grease in fitting to flush some grit out I suppose. Thanks again
Old 10-29-2014, 10:07 AM
maddog784's Avatar
I have rebuilt spindles on a 50" deck. Two tapered roller bearings, two outer races, and two seals should do the trick. It's not too bad of a job - good luck!
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 10-29-2014, 10:31 AM
Just my 2 cents but if you have the re-buildable type, I'd take them apart, clean out the old grease, clean the parts, inspect the bearings, replace any bad parts and re-assemble. Think a lot of us have tried the "I'll pump a bunch of new grease into them and hope it works". I've always ended up taking them apart after that and just had more of a mess to clean up.
Old 10-30-2014, 07:40 PM
Rob C's Avatar
My problem is, I'm not sure if they're rebuildable. I'm very unfamiliar with decks. I'll have some free time this weekend to get tractor put together (basket case) and then I'll try to work on spindles. Maybe they are just rusted to cap and appear to be non-buildable type I guess. I'll give it a shot this weekend.. thx folks.
Old 10-30-2014, 08:31 PM
Rob C's Avatar
OK... I was curious after ya'lls posts, so I took apart what i could on spindle. I was able to remove spindle housing cap. I'm now stuck with trying to see how the bearing is removed from the shaft. there appears to be a locking collar holding bearing on? How is this removed so I can access bearing and check spindle for any damage as well as bearing?
Old 10-31-2014, 05:57 AM
Post a pic of your spindles. If this is what you have then no the spindles are not rebuildable.
http://www.partstree.com/parts/?lc=c...&dn=0072400002
Old 11-02-2014, 08:05 AM
Rob C's Avatar
Unhappy
Sorry it took so long. I've been working to put Cub back together. Here's a pick of the spindles I have. They appear to be what you've posted...Is there a not break the bank alternative out there?
Old 11-02-2014, 08:24 AM
Rob
If it was me I'd look for a later deck with spindles like in the 1st pic. The second pic is a 44" GT deck I rebuilt with this style spindle. Look on C-List, Flea bay or call the sponsors. You can probably find a decent used deck for less than your style spindles will cost you. Also the later spindles will bolt onto your shell if you want to go that way.
