Old 10-24-2014, 10:04 PM
kostendorf's Avatar
Default How does this come apart
How does the keeper on the hyd. valve linkage come off? I can't get to the u clamps holding the back plate on the steering column without taking the valve loose first. I'm taking the steering column off to repair or replace it.
Old 10-24-2014, 10:17 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
it works like a master link in a go cart chain. you either push it up or down and it slide's out of the pin grooves. then you can slide it out
Old 10-24-2014, 10:35 PM
kostendorf's Avatar
That's what I thought but its got a solid link on both sides and it don't slide. Can I tear it off and use c clips?
Old 10-24-2014, 10:54 PM
dvogtvpe's Avatar
you can see the slots of the master link in the photo .
Old 10-24-2014, 11:14 PM
kostendorf's Avatar
Closer view. There isn't any way to move it.
Old 10-24-2014, 11:27 PM
The thinner external piece with the grooves in it looks to slide down. Throw som PB on it and it should move, then remove the thicker piece and slide link out. The top of the thin piece is slit
Old 10-24-2014, 11:31 PM
kostendorf's Avatar
Ok, I'll spray it and look at it again in the morning.
Old 10-24-2014, 11:56 PM
Kieth,
It is split in the middle at the bottom. Pry it out and over to release the bottom, then shove it up to get the top. See pic. Make sense?
Old 10-25-2014, 12:04 AM
bolivier's Avatar
bolivier bolivier is offline
You do that drawing in paint? Looks pretty good.
Old 10-25-2014, 12:08 AM
Yeah, I did. LOL, it took me forever to get it right!! Or I would have posted it sooner.
