Old 10-19-2014, 10:53 PM
NE149's Avatar
NE149 NE149 is offline
Default K321 going back in the 149
Got my Kohler rebuilt, and just got to putting the motor back in the 149 today.
Old 10-19-2014, 11:11 PM
Cool, how's it run?
Old 10-19-2014, 11:23 PM
NE149's Avatar
Cool, how's it run?
Haven't got it started yet, have to mount the choke cable, and figure out where my starter ground runs to, and then I will re-connect the battery and should be good to go.
Old 10-20-2014, 09:47 AM
Hey bud! I was farming yesterday and couldn't get back to you.
Did you find the timing window? If not, look here. If you still can't find it, pull the starter and look on the front of the flywheel housing. Sometimes it's kinda hid.
The starter grounds through the block. You can put a strap/wire from the mounting base to the frame if you want, but that engine bolts in the frame so it should be fine.
Old 10-21-2014, 01:13 AM
NE149's Avatar
No problem! I realized it wasn't on the flywheel cover but on the bearing plate... Got it figured out! I'll see if I can get the ground wire to one of the starter mount bolts...
Old 10-22-2014, 10:52 PM
NE149's Avatar
Got it running! Sounds fantastic!
Old 10-22-2014, 11:12 PM
Awesome!! Did you remove the balance gears during your rebuild. I did on mine and other than watching her "shake like my sister Kate" a little, there is no difference (other than the obvious that it runs better after being rebuilt).
Old 10-22-2014, 11:22 PM
NE149's Avatar
Yes I did, I need to adjust my idle speed a little faster but when she is at the idle she is supposed to be she runs like a top!
Now I need a new exhaust, new seat and put her back together and be good to go!
Old 10-22-2014, 11:39 PM
bocephus1991's Avatar
Happy she's running good for you! What did you use for break in oil?
Brian
Old 10-22-2014, 11:43 PM
NE149's Avatar
I have standard 30W in it now, we used it for assembly. I need a new fuel line hose, I've got one in there but it's too large, however I did get it to clamp down.
