Old 10-19-2014, 02:21 AM
Calvinc Calvinc is offline
Default Cub Cadet 129 Mower Clutch
Hello everyone!
Excited to announce that after having my cylinder head resurfaced, installing a new head gasket, and re-setting the timing (according to Matt's procedure found on this website) my little 1973 model 129 is running and starting much, much better, even considering the large amount of blow-by.
Anyway, now that I have the cub starting and running more reliably, I want to get the mower deck back on it before winter comes so I can test it out! As of right now, the clutch on the front of the engine is stuck, so I disconnected the linkage so I could start and run the machine without the pad slowing everything down.
So my question is, since I've never worked on one of these types of clutches before, is there an easy way to get one freed up, or is it possible to buy an electric one like is on the newer machines? My dad said those mechanical ones never did work very well, and so I thought it might just be easiest to buy an electric one if possible.
Thanks for your help! This site has already helped a bunch!
Calvin
Old 10-19-2014, 02:59 AM
tonka.scout800a tonka.scout800a is offline
Calvin
Do you mean it is always turning? Is there a belt connected to the pulley? Check the pto wear button? maybe it is too worn and not engaging the clutch?
Not sure if you can get an electric one or not, but the mechanical pto isn't that hard to rebuild. There are several threads here for guidance. I rebuilt my pto a few months ago and posted on it. The one thing that stands out to me is that there was a long and short set screw in each hole holding the pto on the shaft.
Old 10-19-2014, 06:51 AM
The engine block has to have the "mounting bosses" cast into it along with being drilled and tapped for an Elec PTO. The 129 has no such provision.
A suggestion, pull the Mech PTO clean it up, and rebuild it.
Old 10-19-2014, 08:47 AM
Service procedure for the PTO is in this manual.
http://www.onlycubcadets.net/forum/s...ead.php?t=4644
They are not all that bad to work on. Did my first one a couple months ago on my 149.
Old 10-19-2014, 05:10 PM
Okay, thanks everyone. The manual will help a lot I'm sure. Do I have to pull the motor to work on it?
Calvin
Old 10-19-2014, 07:21 PM
No but it is easier if you remove the grill.
Old 10-21-2014, 09:08 AM
The mechanical ones work great IMO.......rebuild yours and it should be just fine for years.
Old 10-22-2014, 11:00 AM
I agree, I'd much rather have a mechanical PTO. Actually the electric PTO ( among many other things ) is what keeps me away from a ql tractor.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-22-2014, 02:27 PM
The mechanical seems pretty simple once you get it off.
