Old 03-21-2010, 11:05 PM
EricT EricT is offline
Default Adding Hydro lift
I was wondering if i could add hydro lift for front and rear lift on a cub 128. If so what all would i need to do it?
Old 03-21-2010, 11:08 PM
ihnick's Avatar
ihnick ihnick is offline
theres a power steering pump system. mattg knows more about it
Nick.
Old 03-21-2010, 11:18 PM
I want to make it look as close to original as possible, like it was made to be there, not a hack job. No offense, so if anyone can tell me how and what items i will need to do it, i would appreciate it.
Old 03-21-2010, 11:35 PM
ihnick's Avatar
ive seen it done with a power steering pump and its well hidden and it uses the same lift lever as like a 149 does.
Nick.
Old 03-22-2010, 01:33 AM
murphycc
Guest
Posts: n/a
http://www.onlycubcadets.net/forum/s...2701#post22701
Scott
Old 03-22-2010, 02:45 AM
Default adding hydraulics
could you send me your email, or allow private messages.
Old 03-22-2010, 03:25 AM
murphycc
Guest
Posts: n/a
murphycc@yahoo.com
Scott
Old 03-22-2010, 08:06 AM
You can use the cylinder, valve, handle, etc. from a 149/169 or 1450/1650 and either hide a pump like Scott did (which is going to be a bit more difficult on a 128 because there is a lot less room under the dash and under the fenders) or put a power steering pump on the right side, run from a belt on the flywheel side of the engine.
Old 03-22-2010, 01:34 PM
Matt- why is that my 128 is a bare bones, and has nothing where scott's did. they are both wide frames if memory serves me right. What I am trying to say is my 128 looks to have the same amount of spacing and clearances that scott's did.
Old 03-22-2010, 03:36 PM
The 82 series tractors have a separate battery box and fender assembly; on the 128, these two items are welded together, and there are a couple of sheetmetal stiffeners that run parallel to the frame, one of which is exactly where Scott put his spin-on hydraulic filter. Similarly, his relief valve is located in an area that is far more difficult to access on a 128, as fenders and battery box are one piece, as I mentioned. You may need to move these things to a different location for ease of access. Also, because the frame folds out and over at the front of the 82 series tractors, there is more space in the engine compartment and under the dash.
I'm not saying it's going to be impossible, but these are the issues I see.
